buzzing noise under dash
Posted: Mon Jul 04, 2011 8:17 am
by craggy
l turned on the ignition on my sj413 and the headlights came on, but they were a bit dull,also there was a relay buzzing under the dash,passenger side. The buzzing stopped when l turned on the side or headlights. l hadn't run it for 3 weeks. Any ideas what it might be ? craggy.
Re: buzzing noise under dash
Posted: Mon Jul 04, 2011 9:43 am
by Edweird
Bad connection on the relay perhaps. If you can work out which one it is, take it out and give the connections a clean and see if that helps.
Posted: Mon Jul 04, 2011 6:01 pm
by Tramp
check the dip/dim unit in the passenger foot well. if it is this unit, a lot of people just remove it (although Darrell seemed to think you may need to connect one wire through) but remove it and see how it works,
Posted: Mon Jul 04, 2011 10:24 pm
by craggy
thanks guys,l will check it at the weekend.Did they run a dim dip system when you drive on sidelights only ? lt is many years since l came across one.
Posted: Tue Jul 05, 2011 9:31 am
Yeah it puts the headlights on really dim when you turn the sidelights on...
When it breaks it normally tends to just leave you sidelights and headlights stuck on dim!
