fog wiring?
fog wiring?
Anyone have a diagram?
Re: fog wiring?
You called ..................
- Headlight foglight.jpg (268.3 KiB) Viewed 7123 times
Re: fog wiring?
Is that for the rear darrel? I could just do with knowing what colour the wire is
Re: fog wiring?
Yes the rear.
One green with blue tracer. Switched live.
One green with black tracer. Switched earth.
Switched earth because the foglight will only work with the headlights on.
Re: fog wiring?
so do they both go to live?
Henry
Henry
Re: fog wiring?
just been for a look, i have 2x grey/green trace wires coming from 1 spade on the switch and one grey/green trace by the lights. So put that to my fog job done?
Re: fog wiring?
I have no idea.
Why the hell didn't Suzuki just stick too the same colours, it would make life so much easier.
I believe you have a spanish one and my diagrams are for jap crap
Re: fog wiring?
Yerp im on Spanish.
When i get my undicator stalk ill turn it on and pop the multi meter on it
Re: fog wiring?
Probably not that easy, That may well be the switched live for the foglight.Henry wrote:just been for a look, i have 2x grey/green trace wires coming from 1 spade on the switch and one grey/green trace by the lights. So put that to my fog job done?
The earth wire for the fog light comes from the headlight switch but also goes to the foglight switch to make the warning light come on.
If you earthed it direct it will work any time the fog light switch is operated and I would assume this is not correct for the MOT.
Re: fog wiring?
As you said get the meter on that wire and see if it's switched live or not, but there should be another free wire at the foglight if your lucky.
