Headlights (Main Beam)
Posted: Wed Jul 20, 2011 12:13 am
Hello,
All lights now work on the SJ apart from ONE Even the rear lights now work
Anyway the issue I have at the moment is that the main beam does not work. Side lights work, dipped headlights work but main beam does not.
How do you put them on when driving the SJ. Do you push the left stalk away from you or do you pull it towards you?
Then to flash someone do you pull it towards you or away from you?
Was wondering if here is some relay where you can do both by pulling the stalk towards you. If so where is that located so I can check that is working? Checked the wiring diagrams and cannot see any relays.
Could it be as simple as a 10A fuse that has blown? That is my next thing to check.
MOT is planned for Friday afternoon so need to sort this ASAP.
Thanks,
Rob
Thanks,
Rob
