steering box issues oh and power steering questions
Russ24
Post by Russ24 » Wed Jul 27, 2011 12:03 am
yeah... bastard thing is leaking....
didnt even know there was shit in there!
solution please.
coudlnt find the stickies here.
want to find out the possibilities/issues involving fitting power steering to my sj.
p.s sorry for any crap speelllling... beer inhibits my ability to perform good grammar n shit.
:russ:
Russ24
Re: steering box issues oh and power steering questions
Post by Russ24 » Fri Jul 29, 2011 12:55 am
hello?
doesnt anyone reply anymore?
what do i need to do to convert my sj to power steering? as i cant find the stickies.
funck you very much.?
:russ:
Post by ROBBIE » Fri Jul 29, 2011 8:56 am
russ you want either a vit system pump pipes steering box or you can swap the steering box for a jimny 1 and you wont have to make a wedge.
cant tell you how to do it caus i aint done it
Post by ScottieJ » Fri Jul 29, 2011 9:34 am
as robbie said all you need is the complete set up of a vitara including the double bottom pulley and to make a wedge or a jimny steering box instead of a wedge.
it all bolts up pretty easily and all you need to do is shorten the steering column using a hammer :thumbup:
if you want i can take some measurements off my wedge so yo can make your own :doublethumbs:
Henry
Post by Henry » Fri Jul 29, 2011 10:41 am
What engine you running? 1600 makes it easier, 1300 is possible,
1600 comes with bottom pulley, water pump and alternator all suited to the PAS set up. They run flat belts (1300 runs V belts and no PAS pulley on the bottom)
This is easily changed with swapping the pulleys
Next you need your pump, be careful it does not fowl on the chassis rail as mine is close (2mm) res can be bolted to the jack stow on the front wing. Pipes then run down the front of the chassis to the box.
As said, you can either use a jimny (direct swap no issues)
Or
Vitara. You will need to make a wedge, and shorten your steering arm coming from the bulk head. Apart from that easy :lol:
I run the vit box set up, to give you a bit of an idea
Russ24
Post by Russ24 » Fri Jul 29, 2011 8:49 pm
im running the 1300..... how possible is it todo?
im sorry.. sounding like a fool...... wedge??? im not following
:russ:
Post by turbo-tom » Fri Jul 29, 2011 9:40 pm
this is the wedge.....
(from diffl0ck cynic-al) can remove pics ;) if needed to )
diagram
Post by Darrell » Fri Jul 29, 2011 9:40 pm
Have a shifty here..........
http://forum.difflock.com/viewtopic.php ... ight=wedge" onclick="window.open(this.href);return false;
Brooem
Post by Brooem » Sun Jul 31, 2011 9:32 am
I have every thing apart for the wedge and the modified pulley for sale? Any good to you?
http://www.facebook.com/profile.php?id= ... 2854790809" onclick="window.open(this.href);return false;
:bluefront:
Russ24
Post by Russ24 » Sun Jul 31, 2011 11:29 am
Southwales-Suzuki wrote:I have every thing apart for the wedge and the modified pulley for sale? Any good to you?
yes please. that would be excellent. theres no if buts or maybes about it... i need to do this as i neerly turned the fucking thing over the other day.... aquaplaned.... and without power steering we all know that aint fun...
the wedge i can make up.. well i can convince someone i know who can weld.
:russ:
