Engine specs
Engine specs
Post by ScottieJ » Thu Aug 25, 2011 12:49 pm
This sheet is a work in progress, feel free to add any info to this thread and I will update it :thumbup:
Weights
G16 is around 104KG (230lbs) with everything fitted, water & oil & including the rad.
G13BA 1298cc 85.558kg. The complete engine as you might expect to be lifting it out (with manifolds, carburetor, air cleaner, alternator, clutch, radiator hoses and oil but no starter motor)
diesel conversion as a comparison: A 1.9 VW TDI is around to 180-200KG
Other useful Links about suzuki engines
Team Swift
Pirate4x4: Suzuki cylinder heads
