Bling
Re: Bling
It's just a 1.3 8v with gsxr carbs and a 1.6 8v head but a fawking sexy one!
Here's the specs
Motor: 1.3 .020 over and deck shaved,
I used dish pistons because of the decking,
1.6 Reynolds ported polished and larger valves and shaved head.
Caution: They are a bit hard to deal with.
Isky cam Beware the cam timing sheet is incorrect. They use a 1.6 rocker ratio and it should be 1.3 ratio.
I used Hawk Suzuki Cam 2 specs and that worked out great.
Adjustable timing gear Because of the shaving of the head and block.
I also had to make a custom timing adjuster wheel. It was to small in diameter and was unable to get the
timing belt tight.
Internals are balanced and flywheel,
I'm going to try a Centerforce clutch this time.
The intake was made from a solid block of 6061. It started at 35 pounds when the machining was done it was 8 pounds. I also decided to machine the water ports in the manifold. The carbs are 32mm Katana carbs. The external accessories on the motor I have also machined up. The distributor has been switched to mechanical.
I have started it and it runs great. This was a lot of trial and error with return line sizes and tuning.
The manifold was very time consuming so I would not make another.
Here's the specs
timing belt tight.
- dominic
- Can I have a tow
Re: Bling
WOW wot a super sexy engine.
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
- dominic
- Can I have a tow
Re: Bling
Dom
Currently Drive
Re: Bling
lol women just don't understand!!!
I'd rather look through a book of tuned G series engines than a porn magh
