Distriutor
dcallaghan2011
Distriutor
Post by dcallaghan2011 » Fri Oct 21, 2011 5:57 pm
Hi, on sunday i am planning to pick up a vitara 8 valve carb engine to do a conversion in my SJ. I was wondering what distributor i should use as the engine i am getting comes with one, i have read in some places to use the 1.6 one and in other places to use the 1.3 one. if i use the 1.3 one would i need to do anything to the timing or something like that and if i used the 1.6 one would i need to adapt any of the wiring?
thanks,
dan
Re: Distriutor
Post by ScottieJ » Fri Oct 21, 2011 7:21 pm
Use the 1.6 one :thumbup: wiring should be the same but if the colours don't match post up and ill talk you through what goes where if you want.
dcallaghan2011
Re: Distriutor
Post by dcallaghan2011 » Fri Oct 21, 2011 9:14 pm
Ok thanks, thats great
Re: Distriutor
Post by twiss » Sat Oct 22, 2011 11:59 am
Yeah it's dead easy.... there's only like 5 or 6 wires...
