got a 2" lift, standard 410 engine/running gear etc... anyone know what is the best tyre size for this set up and what tyres shall i get?
need to be fairly good on road and not too expensive! thanks
tyres
Re: tyres
only shackles at the moment, mainly because my old ones were knackered and i'm saving for a proper lift kit anyway!
Re: tyres
The option I chose was cutting down the gay extended shackles so they give about an inch of lift, then stuck add-a-leaves in.
Gives about 2.5 - 3 inches lift, and I've got wheel spacers as well
Then you can fit 235x80r15s on with no rubbing
Although, it will make it slower so you might want to go with 215s or 225s to keep some of your acceleration
