Skid plates
Skid plates
Does anyone use any or any other under body protection.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Skid plates
I've seen before someone who got a massive sheet of steel and covered the underside of a vitara with it
Re: Skid plates
I want to make some from Kevlar so am looking for some pics & dimensions if nay one can help??
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Skid plates
I have a transferbox guard and that's it, all you really need on an SJ IMO
Now that I've raised the transferboxes for a flat belly I might make a flat bottom for it now though. Not for protection, just to help the sj 'slide' over things.
Re: Skid plates
Do you have a picture of it & know the dimensions?
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Cherry Bomb Exhaust
Llama Brake Hose
Re: Skid plates
Thing is I've got dual transferboxes so it's a bit different
But there is this floating about, you weld it to the existing mounts and then add a bit of extra bracing to the existing mounts.
