Idle speed adjustment screw loaction 89 sj413?
timpaton
Post by timpaton » Fri Dec 09, 2011 3:15 pm
Hi,
Does anybody know where the idle speed screw is on the standard Asian carb on a 89 413?
Cant find it, been staring at it a couple of times, in the dark, and the rain, with a torch, and i cant find it? Help?
Tim
Re: Idle speed adjustment screw loaction 89 sj413?
Post by ScottieJ » Fri Dec 09, 2011 3:58 pm
idle screw.JPG (47.33 KiB) Viewed 4963 times
That's the best pic I could find. These carbs have an Idle up system that can cause problems when they go wrong, could you describe what your problem is as it could be something to do with that system?
Thanks
Scott
Christoff
Post by Christoff » Fri Dec 09, 2011 6:15 pm
Yeah I'm sure everybody with these carbs has high idle issues especially when cold. Adjusting the Idle screw isn't going to cure it.
What is the idle up system you mentioned ?
timpaton
Post by timpaton » Sat Dec 10, 2011 6:08 pm
Thanks, thats very kind of you. i have now made the adjustment, and have rectified the fault. that really helped.
