Buying a SJ410
spjonesuk
Buying a SJ410
Post by spjonesuk » Wed Jan 25, 2012 11:58 pm
Sorry to bother you all, I'm looking into buying a Suzuki SJ 410V (I really want one!) http://www.ebay.co.uk/itm/suzuki-sj-410 ... 3a6ef88d0d" onclick="window.open(this.href);return false;. I'm not to bad regarding basic maintenance but do you think this would be too much for myself as its got a gearbox problem or maybe the guy is wrong?
Any comments much appreciated.
rgonzobull
Re: Buying a SJ410
Post by rgonzobull » Thu Jan 26, 2012 6:53 am
Well it does come with a replacement gearbox. Providing its the right one and in good condition then thats one problem sorted out as changing gearbox is a simple bolt out and in job.
However it does appear to possibly need some welding doing. If this is the case then only you can answer if you feel your welding is good enoegh or if you are willing to pay a friend/garage to do the work.
Theres plenty of advice and help on here to help you through it all. But take your time buying one and make sure you see it properly before you bid so you understand exactly whats required. Good luck
LJ80Q
Highlander
Re: Buying a SJ410
Post by Highlander » Thu Jan 26, 2012 10:51 am
Go for it!
its MOT'd till November and doesnt sound too bad at all.
if it was nearer me I'f have it! :D
These SJ's are just like Meccano kits, a few nuts and bolts hold everything together and very easy to work on.
Parts are still available and cheap enough too, even if you were to blow an engine for example, a new engine can be picked up for £100 and fitted in a few hours
Newtomud
Re: Buying a SJ410
Post by Newtomud » Thu Jan 26, 2012 7:26 pm
spjonesuk wrote:Sorry to bother you all, I'm looking into buying a Suzuki SJ 410V (I really want one!) http://www.ebay.co.uk/itm/suzuki-sj-410 ... 3a6ef88d0d" onclick="window.open(this.href);return false;. I'm not to bad regarding basic maintenance but do you think this would be too much for myself as its got a gearbox problem or maybe the guy is wrong?
:welcome: to the club..
I've just clicked the link and bidding has ended? If you've bought it I hope all is well with the new project... If you missed it there'll be plenty more along.. With Ebay I find patience is needed and the right sj will come along.. Good luck :thumbup:
rgonzobull
Re: Buying a SJ410
Post by rgonzobull » Thu Jan 26, 2012 7:39 pm
So........did u win it?
LJ80Q
Re: Buying a SJ410
Post by dan_2k_uk » Thu Jan 26, 2012 8:01 pm
rgonzobull wrote:So........did u win it?
I'm keen to find out aswell.
spjonesuk
Re: Buying a SJ410
Post by spjonesuk » Thu Jan 26, 2012 9:12 pm
Im going to look tomorrow? anything I should look out for?
Thanks for all the comments.
Re: Buying a SJ410
Post by ScottieJ » Thu Jan 26, 2012 9:33 pm
Just look everywhere on the body for signs of bad rust :lol:
Smoke on start up, play in wheelbearings, transferbox outputs, diff flanges, UJs etc.
Just have a good look around and climb underneath for a good look and try and move anything you think shouldn't etc.
spjonesuk
Re: Buying a SJ410
Post by spjonesuk » Thu Jan 26, 2012 9:43 pm
Blimey got any pics of these things as im new to 4x4 completely!
Sorry
rgonzobull
Re: Buying a SJ410
Post by rgonzobull » Thu Jan 26, 2012 9:50 pm
Best money you will spend in my opinion is take it to an MOT garage you know and ask them to MOT it. Best few quid you will ever spend. You can then use result as a barganing tool As I say only my opinion
LJ80Q
