413 to 410 tbox
jgp1986
413 to 410 tbox
Post by jgp1986 » Sun Jan 29, 2012 11:44 pm
im newish to all this but ive got a 410 tbox to fit but it has the brake on it, but my sami has the hand brake on the rear drums, which is better to use or am i confusing myself,, heeellllppppp :screwy:
thanks in advance
cheers
jonno
justaddmud
Re: 413 to 410 tbox
Post by justaddmud » Sun Jan 29, 2012 11:53 pm
personally I prefer the t-box break, as it adds another breaking part to the overall system, plus means less messing about if you switch to rear discs
I ran a Sammy with wheel breaks, and fitted the 410 box with brake, and just didnt use that part, yes, you are carrying a couple of extra kilo's of weight but means it is there if ever you convert/have problems with the rear breaks
jgp1986
Re: 413 to 410 tbox
Post by jgp1986 » Sun Jan 29, 2012 11:58 pm
ahh ok thanks ill run it and just not use it then unless i have to, not really thought about disc conversion yet, still got lots to do and as for the extra kilos its ok its not the lightest of sj's,
cheers
justaddmud
Re: 413 to 410 tbox
Post by justaddmud » Mon Jan 30, 2012 12:01 am
I have the other problem, i have another t-box in my garage to fit, as my current one is a bit noisy, and i have to change the brake drum from one to the other as i need the centre brake (early jap built zook)
jgp1986
Re: 413 to 410 tbox
Post by jgp1986 » Mon Jan 30, 2012 12:04 am
will the hand brake cables cause me any bother, eg length with them being on rear an attached to the body,
i have add leafs and a 2 inch body lift#
