1.6 8v vit timing
ianedwards
1.6 8v vit timing
Post by ianedwards » Sun Feb 19, 2012 8:46 pm
Hi,
Whent up my parents to do a bit more on the sj only to find my dad fiddling with the engine,
Any way,
He's stripped the whole thing, and thought it was a good idea to remove the whole bottom pully to get the cover off, there for removing the timing belt and messing the lot up. :poke:
Then he removed the top pully,
I've seen the bottom pully is on a key way and the top is on a pin so they should go back ok,
Has any one got any idea how to set the timing back up properly, any help would be great.
Ian
Ian. :)
Re: 1.6 8v vit timing
Post by dan_2k_uk » Sun Feb 19, 2012 8:55 pm
Get the cylinder closest to the front at tdc using a screwdriver through the plug hole or offering the cover up and using the marks. Then get the arrow on the cam pully to point vertically up. Refit belt and fire it up.
If the dizzy hasn't been fiddled with it should be fine.
Dan
Post by ScottieJ » Sun Feb 19, 2012 9:01 pm
http://www.suzukiclubuk.co.uk/index.php ... =13&t=3202
Read the above link for setting up the timing.
As for the bottom crank pulley, make 200% sure you get it torqued back up properly as if it comes undone it will ruin your crank!
ianedwards
Post by ianedwards » Sun Feb 19, 2012 10:30 pm
to be honest i don't know what he's done all together,
he could have messed with anything. put it like this, there is nothing on the engine at all, just the block and head and water pump. suppose im lucky he didn't decide to split it. lol ive got assume everything is wonky.
just taking that bottom pully off wont do any damage, will it ?
so ive got to get that bottom pully back on, line it up with the key way, and torque it up - i.e swing on it with a pole.
he did say it was tight. lol,
just taking it off wont do any damage, will it ?
i know he was only trying to help, but grrrrrrrrrr
Ian
Ian. :)
Post by dan_2k_uk » Sun Feb 19, 2012 10:32 pm
Na not going to cause any probs. Just make sure it goes back nice and tight!
ianedwards
Post by ianedwards » Sun Feb 19, 2012 10:38 pm
tidy,
never mind, i get to clean every thing now lol, it will look good once im finished.
i was surprised how little oil was on the engine, its just grime and crud.
Cheers guys
Ian. :)
dunk
Recommended Trader
Recommended Trader
Post by dunk » Mon Feb 20, 2012 9:00 pm
Here are a few pics that may help
ianedwards
Post by ianedwards » Mon Feb 20, 2012 9:46 pm
nice one.
Will get it back together, but i wont be able to try it for a while
Ian
Ian. :)
