Guide to fixing a snorkel
charger
Post by charger » Tue Feb 28, 2012 10:31 am
Is there one on here anywhere?
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Guide to fixing a snorkel
Post by turbo-tom » Tue Feb 28, 2012 10:37 am
not sure if there is such a "guide" i thought there use to be one on here but now i cant find it , but people make them out of various things drain pipe is a common one , mine is made out of a tractor filter then goes into some small bore drain pipe then into the the air box can get pics when im home from college if you want ;)
charger
Post by charger » Tue Feb 28, 2012 12:34 pm
Yeah that would be great thanks
1991 Samurai
Cherry Bomb Exhaust
Llama Brake Hose
Post by turbo-tom » Tue Feb 28, 2012 10:16 pm
sorry its taken so long but i have been working on sj too :D
here is the top part
goes into the standard airbox all the joints was glued togethere with the correct pipe glue then siliconed around the outside edges
