mixed up diffs
geobel
mixed up diffs
Post by geobel » Sun Mar 04, 2012 3:32 pm
Hi there can anyone help me I recently bought a sj413 samuria for offroading . The engine has struggled a bit since I got it Ihave done all I can to the engine it still struggles so I thought I would check the diffs the front one is marked s or 5.726 on the crown gear and the rear is marked s or 5.794 can you help
Re: mixed up diffs
Post by ScottieJ » Mon Mar 05, 2012 12:17 pm
I don't think those markings aren't the ratio but the pinion depth setting or something like that.
best way to tell is to count the teeth on both the ring and pinions to check that they are both the same!
Highlander
Re: mixed up diffs
Post by Highlander » Mon Mar 05, 2012 7:59 pm
Is it any better in 2wd?
