Oil leak
Oil leak
Post by donkeychomp » Tue Mar 06, 2012 4:41 pm
It's the Exxon Valdiz all over again.
Checked the fuel pump and dizzy, no leaks there. Got underneath the beastie and it seems to be coming from a cracked plate at the bottom of the gearbox, just above the end of the sump.
I can twirl a spanner or two but this is beyond me I think.
Anyone know of a decent 'bars leaks' additive that might seal this up?
Alex
Re: Oil leak
Post by Edweird » Tue Mar 06, 2012 4:56 pm
I have oil coming down that back of the engine too but it's not bad enough that I have to top up between oil changes, so I just left it as was.
Re: Oil leak
Post by ScottieJ » Wed Mar 07, 2012 12:31 pm
Try tightening up the sump bolts very gently as they are small and snap easily if that doesn't stop it get a new gasket for the sump and try that.
If that doesn't stop it then it could be the rear crankshaft oil seal and that's a gearbox out job, still not hard to do though!
Re: Oil leak
Post by donkeychomp » Wed Mar 07, 2012 2:10 pm
Going to try tightening the sump...fingers xxd.
Re: Oil leak
Post by ScottieJ » Wed Mar 07, 2012 2:27 pm
I always use a small 1/4" drive as you can't put as much force on it that way :thumbup:
Re: Oil leak
Post by donkeychomp » Thu Mar 08, 2012 12:50 am
It's the oil seal. I can't do that myself, just not good enough.
The anus is my only car and as a carer I need to use it every day.
At a bit of a loss now...can't pay for it to be fixed, guess I'll drive it till it goes pop.
Thanks all here for your help and info, if anyone wants to buy 'Piglet' she'll be on ebay soon enough, with a mullered engine.
Alex
Highlander
Re: Oil leak
Post by Highlander » Thu Mar 08, 2012 9:39 am
Alex where are you?
I know I'm probably about a million miles away from you but I would do it for you.
Maybe someone nearby could help you, its not a difficult or complicated job to do.
If its your only car and you need it, then driving it till it breaks doesn't seem the ideal solution.
Re: Oil leak
Post by dan_2k_uk » Thu Mar 08, 2012 10:22 am
To put it simply.
Remove little prop between gearbox and t-box.
Release clutch cable.
Unplug reverse light switch.
Remove 2 bolts holding starter on and hang out of way.
Remove gear gaiter and remove 3 bolts holding shift lever into box
Undo 2 bolts holding bar under gearbox.
Undo 2 bolts in rear gearbox rubber mount.
Undo 4 bolts holding gearbox to engine.
Lift down and out of way.
Remove clutch and flywheel.
Replace seal.
Reverse of above.
Dan :thumbup:
Re: Oil leak
Post by ScottieJ » Thu Mar 08, 2012 12:13 pm
If you can change a wheel you can drop a gearbox :lol:
It's honestly not hard, no point selling up for such a simple problem!
Re: Oil leak
Post by twiss » Thu Mar 08, 2012 1:43 pm
Yeah if you're around my area I'll give you a hand for some beer tokens ;)
I'm sure out other spanner happy members will help you out as well! :)
Taking your gearbox off is dead easy! The only specialist tool you may need is a clutch alignment tool but they are cheap and easy to get hold of!
I once swapped a box and rebuilt both my axles in a day (in 6" of snow) just so I could go out and play in the evening!
I'm not a mechanic by any means, I'm in IT for gods sake! ;)
