cherry bomb
Posted: Wed Apr 11, 2012 7:56 pm
by dazerede
i would like to get a cherry bomb exhaust but cant find and inlet small enough to fit on my 410 sj my inlet it roughly 30mm yes i now pee shooter and the smallest inlet i can find on a cherry bomb is 38mm would it be alright to modify it a bit
Click Here for Ebay Listing
Re: cherry bomb
Posted: Wed Apr 11, 2012 8:00 pm
by dan_2k_uk
I just scaled mine down with a few other bits i had untill it was the right size by the time it got to the flange in the middle of the system.
Dan
Re: cherry bomb
Posted: Wed Apr 11, 2012 8:01 pm
by turbo-tom
dazerede wrote:i would like to get a cherry bomb exhaust but cant find and inlet small enough to fit on my 410 sj my inlet it roughly 30mm yes i now pee shooter and the smallest inlet i can find on a cherry bomb is 38mm would it be alright to modify it a bit
could pug it by mig welding it but thats bit of a bodge at 8mm
or another option what i would to is cut loads of equal lines down the tube and bend then inwards onto the 30mm pipe then weld it up
another option use one of theses because you would be able to crush the 2mm differents with a exhaust clamp n paste
Re: cherry bomb
Posted: Wed Apr 11, 2012 9:02 pm
by dazerede
chears might go and do some shopping naw
Re: cherry bomb
Posted: Thu Apr 26, 2012 12:45 pm
by charger
I have a Cherry bomb silencer, from the manifold I have a Peugeot 206 exhaust system that goes into the Cherry bomb. Sounds great & everything fits well.
Re: cherry bomb
Posted: Thu Apr 26, 2012 1:52 pm
You could weld a ring around the exhaust pipe, then weld the cherry bomb onto the weld line.
That will give you a bit less distance to bridge!
