Page 1 of 2
transmission brake shoes
Posted: Mon Apr 23, 2012 5:03 pm
by phil1511
hi does anybody know where i can source a set of brake shoes for the transmission brake on a sj 413 1998 thanks phil
Re: transmission brake shoes
Posted: Mon Apr 23, 2012 5:11 pm
by Highlander
I have a good spare set..
I'm working away from home till next Tuesday but will have a look when I get back and make sure.
Are yours worn? I've never seen any with a lot of wear, maybe they've been stuck on?
Posted: Mon Apr 23, 2012 6:11 pm
by phil1511
hello no the the brake shoes were not on there when i brought it neither was the brake drum im guessing they took it off because it was stuck on but luckly i still have the drum but no shoes.
Posted: Mon Apr 23, 2012 6:18 pm
by Highlander
So did they replace the drum with a spacer?
I think I actually have the complete unit, backplate/shoes/springs etc minus the actual drum itself
Posted: Mon Apr 23, 2012 6:43 pm
by phil1511
im not sure what spacer you mean ? could u explain please
and if u do that would be handy if you wont to sell it that is ?? because i dont acctually have the springs or the lever part.
Posted: Mon Apr 23, 2012 6:52 pm
by Highlander
If you look at this pic of an SJ transfer box (this one has PTO fitted) you'll see the handbrake drum on the left side.
In models without the handbrake drum there is a round spacer/pulley fitted instead, similar to the one that the front prop is attached to (bottom of the pic)
Will have a look when I get back and make sure its still there :)
Posted: Mon Apr 23, 2012 7:01 pm
by Darrell
Seems like you may be sorted :thumbup:
But anyway, the first time I've searched for handbrake shoes and actually found any
Click Here for Ebay Listing
Part numbers are here http://forum.suzukiclubuk.co.uk/vi ... 14/t,4727/
I thought there was only 1 set of shoes for all transfer box handbrakes, but the ebay ad says there's 2
:er:
Posted: Mon Apr 23, 2012 7:32 pm
by ROBBIE
i got a set somewhere and i know http://www.rhinorays.co.uk/index.htm does them
Posted: Fri May 04, 2012 12:31 am
by phil1511
hello again i was wondering if u had and luck finding the complete backplate ?
Posted: Fri May 04, 2012 10:28 pm
by rockwatt
I've got quite a few full units ! I always save them complete if there in good condition.
£15+p&p complete
And there are 2 different types jap and Spanish.
