Headlights come on when i push brake pedal???
lifeisshort
Post by lifeisshort » Tue Apr 24, 2012 9:30 pm
Hi bit of a newbie to cars and recently got a sammy.
i noticed the other day that when pushing the brake pedal the headlights come. Any one know why this could be? or any solutions.
Thanks
Re: Headlights come on when i push brake pedal???
Post by Darrell » Tue Apr 24, 2012 9:46 pm
Never heard of that before :lol: .
It is the main headlights not just the sidelights :er:
Highlander
Post by Highlander » Tue Apr 24, 2012 10:36 pm
Must be a bad earth or a short somewhere.
if it is the actual headlights i'd check the fuseboard for shorting.
if its the sidelights i'd have a look at the rear light wiring first
Post by Edweird » Tue Apr 24, 2012 10:37 pm
Well that's a new one. I wonder if it's been rewired by someone.
Highlander
Post by Highlander » Tue Apr 24, 2012 10:49 pm
Thinking about it, have you replaced a brake bulb?
if the wrong bulb has been fitted it could be shorting the light circuits and putting your lights on.
try removing the brake light bulbs and see if it still does it.
OR
Do you have a towbar fitted?? check the towbar wiring for shorts
Post by Darrell » Tue Apr 24, 2012 11:09 pm
Highlander wrote:Must be a bad earth or a short somewhere.
:thumbup: If either of the rear light clusters loose there earth it could earth via the sidelight circuit. The lights would not be as bright as normal though. If it's the headlights I haven't got a blooming clue :S
lifeisshort
Post by lifeisshort » Wed Apr 25, 2012 7:12 am
hi all thanks for the help. Its the headligts not the side lights that come on :er: . Ill try taking out the bulbs today and see if the problem still happens.
Highlander
Post by Highlander » Wed Apr 25, 2012 9:16 am
Maybe some mates have been playing with it?? :hahaha:
my pals regularly wire each others horn to the brakes pedal!! :hahaha:
Post by ScottieJ » Wed Apr 25, 2012 10:05 am
Have a look around under the dash near the pedals for any bare wires showing as well, there's always a chance there could be a wire hanging down that is earthing out on the brake pedal as it moves?????
lifeisshort
Post by lifeisshort » Wed Apr 25, 2012 1:55 pm
Hi all thanks for all the help changed the bulbs today and all is fine....for now.
