Starter SJ4 HELP needed
dunnin21
Post by dunnin21 » Thu Apr 26, 2012 8:51 pm
I took my starter motor off earlier because it was working propley after a day at pay and play. stripped it down cleaned with wd40 a resembled. On trying to start the car it dosnt turn over it just makes a buzzing noise and the light on the dash lights up Any ideas
Re: Starter SJ4 HELP needed
Post by turbo-tom » Thu Apr 26, 2012 8:59 pm
dunnin21 wrote:I took my starter motor off earlier because it was working propley after a day at pay and play. stripped it down cleaned with wd40 a resembled. On trying to start the car it dosnt turn over it just makes a buzzing noise and the light on the dash lights up Any ideas
sounds like it might of got a bit stuck just hit it with a long pole whilst someone else is turning the key in the ingtion ;)
might work might not but it worked on mine :smokin:
dunnin21
Post by dunnin21 » Thu Apr 26, 2012 9:01 pm
ill try that is it possible that i have over tightened the long bolts that hold the starter together
dunnin21
Post by dunnin21 » Sun Apr 29, 2012 8:55 pm
few whacks and jump leads sorted the problem out. thanks
Post by turbo-tom » Sun Apr 29, 2012 10:06 pm
good good ;) :pompom:
