i need new headlight bulbs
dazerede
Post by dazerede » Mon May 07, 2012 9:00 pm
i need a pair of headlight bulbs and not sure what are the best to buy thinking of getting these
Click Here for Ebay Listing
4” calmini lift kit :)
Re: i need new headlight bulbs
Post by Darrell » Mon May 07, 2012 9:24 pm
Now why does it say they will fit. The headlamps take p45t don't they :er: .
However you can get upgraded bulbs with this old backplate/fitting which are much the same as those.
Just make sure your headlamps will take H4 before ordering as mine is a 1987 and newer ones may well take H4.
Post by Edweird » Mon May 07, 2012 9:35 pm
I know that the bulbs in my truck are H4s with a T45 fitting. You could probably patch the T45 fitting onto a different bulb using a dremel and soldering it on. You'd just have to be careful that they were central, square and correctly orientated.
Post by Darrell » Mon May 07, 2012 9:47 pm
You can get these easy enough (if you need to)
Untitled - 2.jpg (43.05 KiB) Viewed 5999 times
Post by Edweird » Tue May 08, 2012 10:04 am
Alright, scratch that. Just buy ones with the T45 fitting.
