Reverse switch cable
ianedwards
Post by ianedwards » Sat May 19, 2012 9:57 pm
Hi guys,
Had a bit of accident with my gearbox, I picked the gearbox up to move it, and I was stood on the reverse switch cable, wich now consequently no longer attached.
Is there a certain way the two cables have got to go back on, or doesn't it matter.
I think the later is the case, but want to be sure before I solder them back on.
Ian
Ian. :)
Re: Reverse switch cable
Post by turbo-tom » Sat May 19, 2012 10:02 pm
i had the same problem as you but im pretty sure the lads on here said its just a normall switch so it does not matter what way it goes round ;)
http://forum.suzukiclubuk.co.uk/vi ... 4064/start,/
ianedwards
Post by ianedwards » Sat May 19, 2012 10:06 pm
Thought as much,
Ian
Ian. :)
Post by Darrell » Sat May 19, 2012 10:06 pm
The switch doesn't earth therefore it won't matter which way round you solder them.
ianedwards
Post by ianedwards » Sat May 19, 2012 10:08 pm
Nice one.
Ian
Ian. :)
