HEAT!!!
suzukisteve
HEAT!!!
Post by suzukisteve » Fri May 25, 2012 1:58 pm
Cant take it anymore the doors are coming off!! :doublethumbs:
pickle power!
OllieSJ
Re: HEAT!!!
Post by OllieSJ » Fri May 25, 2012 2:37 pm
good shout my roof is going to be down this weekend and windscreen down door off !!!
Re: HEAT!!!
Post by turbo-tom » Fri May 25, 2012 2:43 pm
good luck taking your doors off , dont use a screw driver because the will snap instantly , best way i belive is chip off all the paint aroudn the screw the hit a shitty flat head screw driver in the slot at angle and follow the screw around as you go ;) if that makes any sence :lol:
Highlander
Re: HEAT!!!
Post by Highlander » Fri May 25, 2012 2:49 pm
I make a nice big slot in them with a thin cutting disc in an angle grinder then gently use an impact screwdriver on them :hahaha:
Don't hit them too hard or you'll bend the bodywork :hahaha:
suzukisteve
Re: HEAT!!!
Post by suzukisteve » Fri May 25, 2012 2:57 pm
as it goes, just as winter was ending, i had a cunning plan... more cunning than a fox.. who had just graduated head of cunning from oxford university!
I GOT THE GRINDER OUT!! :rockin: lol
i cut the tops of the hinges off so i can just lift the doors off! :guns:
pickle power!
Highlander
Re: HEAT!!!
Post by Highlander » Fri May 25, 2012 3:09 pm
But why??
these billet ones are only $239!! :hahaha:
http://www.zuk-n-ovations.com/pages/bod ... inges.html
suzukisteve
Re: HEAT!!!
Post by suzukisteve » Fri May 25, 2012 3:16 pm
f*ck me! why didnt i go for those? :hahaha:
half hour with a grinder and a splash of hammerite, job done!! :thumbup:
pickle power!
Re: HEAT!!!
Post by ScottieJ » Fri May 25, 2012 4:16 pm
Just don't forget to make sure you have at least 2 rear view mirrors otherwise mr plod wont be happy!
suzukisteve
Re: HEAT!!!
Post by suzukisteve » Fri May 25, 2012 4:38 pm
well one of mine has fallen off anyways lol. :roll:
but no i do need some, was thinkin bout mounting some motorbike ones on the wing or something..
pickle power!
suzukisteve
Re: HEAT!!!
Post by suzukisteve » Fri May 25, 2012 4:41 pm
pickle power!
