Tyres Pressure
charger
Tyres Pressure
Post by charger » Fri Jun 08, 2012 3:04 pm
What is the ideal pressure for mud tyres on the road & what can I lower them to for off road. The tyres does not state any figures, they are broncos if that makes any difference.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
Re: Tyres Pressure
Post by ScottieJ » Fri Jun 08, 2012 3:28 pm
Service Manual states 20psi front and rear but 26psi in the rear if carrying weight.
That's what I run mine at. I'm too lazy to change it when off road.
Highlander
Re: Tyres Pressure
Post by Highlander » Fri Jun 08, 2012 4:50 pm
I usually run mine at 20 psi off road depending on the terrain
If its REALLY boggy and wet I've had them down as low as 10 psi
SierraDan
Re: Tyres Pressure
Post by SierraDan » Wed Jan 14, 2015 12:07 am
I run 20-22psi on road and 5psi Offroad.
Re: Tyres Pressure
Post by dan_2k_uk » Wed Jan 14, 2015 6:50 pm
18psi. Can't be bothered to change them off road either...
1066 Boy
Re: Tyres Pressure
Post by 1066 Boy » Thu Jan 15, 2015 10:57 am
Mine are at 20 psi front because of heavy winch bumper and winch with
steel cable at the moment.
Rear are at 15 psi at the moment but as the kja is so light at the back and
the tyres are fat, this is still a bit much at the moment. wheel spin on roundabouts
etc.
Offroad around 10 psi works for me. :salute:
I Know how to work it. Not, how it works...............
believe me, there is a difference!!!
Frenchy
Re: Tyres Pressure
Post by Frenchy » Sun Apr 24, 2016 12:39 pm
I've been reading around the internet and 20 psi to 33 psi (2.2 bar) seem to be the pressures recommended.For normal road use does anyone have the definitive figure?
Re: Tyres Pressure
Post by dan_2k_uk » Sun Apr 24, 2016 2:12 pm
There isn't one because everyone is running different types and sizes of tryes to standard.
Re: Tyres Pressure
Post by twiss » Sun Apr 24, 2016 2:19 pm
Mostly road use I go for 22psi... 30+ psi is WAY too hard
Re: Tyres Pressure
Post by ScottieJ » Sun Apr 24, 2016 11:28 pm
Frenchy wrote:I've been reading around the internet and 20 psi to 33 psi (2.2 bar) seem to be the pressures recommended.For normal road use does anyone have the definitive figure?
30+ is way too hard, standard Sj tyres should be at 20psi and up to 26 in the rear of carrying weight, larger tyres generally have stronger sidewalks so the pressures can be reduced.
