Wee observation/query about these....
I bust the rear brake line last weekend (single line for the rear brakes, no load balancer fitted)
So in true bodge fashion I cut the rear line, bent it over and hammered it so it didn't leak.
The idea was to use the front brakes only.
Bled the brakes and nothing..... no brakes at all, brake pedal went to the floor every time....
Removed and checked all the calipers etc, all free and working fine (had cleaned and greased them all just last week)
Plenty pressure coming out of the master cylinder on both lines, so wasn't that.
On my splitter below the master cylinder, the pipe from the rear of the master cylinder goes into the rear of the splitter then looks to go straight to the rear brakes.
The pipe from the front of the master cylinder goes into the front of the splitter then exits bottom and front to go to each front brake (I have no side exit)
So.... I'm assuming since I blocked the rear pipe/secondary circuit that somehow this meant i got no pressure down the primary circuit to the front brakes??
I swapped the blocked off rear pipe onto one of the front exits on the splitter and the front pipe onto the rear exit, bled them and both fronts were working again 100%
So I know if one circuit starts leaking the other circuit will still work but if one circuit is blocked and prevented from working it looks like this also stops the other from working??
I suspect whatever does this must be within the master cylinder??
Any thoughts?
Brake splitter
- Highlander
- Can I have a tow
Re: Brake splitter
sounds very odd, have you checked that there is no fluid dissapearing from the resivoir?
thats dangerous if your back brakes were to fail on the road then your left with no brakes
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
- Highlander
- Can I have a tow
Re: Brake splitter
Sorry, I should of course have explained this one is only ever used off road.
The back brakes can't fail, they're not connected
No fluid loss and all brakes/MC etc working as they should
I have tried this on another Samurai since with the same result, if the rear brake line is blocked i.e. can'tt be compassed then the fronts don't operate at all.
I can only assume its something within the master cylinder than does this
