Modified Inlet manifold
- ianedwards
- SCUK Addict
Hi, would a modified 1.3 inlet manifold for a sj carb be ok on the vit 1.6.
I spoke to guy who's selling one and says he has one on his 1.6 and it's fine.
Just want to make sure what he says is right,
Ian
Ian
Ian.
Ian.
Re: Modified Inlet manifold
Yeah it will work just fine... I had a modded 1.3 manifold on my vit engine no problems
- ianedwards
- SCUK Addict
ill have to count my pennys
cheers,
ian
cheers,
ian
Ian.
Ian.
It will work but the ports are slightly smaller so technically it will restrict flow. As we're not really running hi performance engines you probably won't notice much of a difference though. Then again stock inlet manifolds flow so badly I wouldn't worry
- ianedwards
- SCUK Addict
Hmmm,
Ian
Ian
Ian.
Ian.
Had a good look at both manifolds side by side and though the ports are slightly smaller the most restrictive bit by far is where it spilts the 2nd time to go from 2 to 4 which is pretty much the same on both of them.
Be sure to let us all know if you find a quick and easy fix for that!
I went for the 1.6 manifold as I had both but cant see it making any noteable difference TBH.
Dan
Dan
- ianedwards
- SCUK Addict
hmmm, to be honest i never really looked at it while the normal 1.6 was off, ill compare them when it comes.
well i bought it, paid for it now ive got to wait for it. hate this bit.
su carb and modified manifold for 100 squid, not to bad i dont think.
Ian
Ian
Ian.
Ian.
Thats what I paid for mineianedwards wrote:hmmm, to be honest i never really looked at it while the normal 1.6 was off, ill compare them when it comes.
Ian
Mine you meanScottieJ wrote: Thats what I paid for mine
Not bad considering I paid £200 for the manifold and carb originally
Nah cuz it's mine nowtwiss wrote:Mine you meanScottieJ wrote: Thats what I paid for mine
