Gearbox woes
Zookii
Gearbox woes
Post by Zookii » Mon Jul 02, 2012 12:53 pm
Hey, I was just wondering if you can help me on a problem i have? I need to replace my sammies gearbox but im unsure of what gearbox i need as its had a engine conversion. It was a 1988 1.0ltr santana but now has a 1.3ltr engine, the problem is i dont know what year this engine is. i have the engine number G13A-243984, is there a way to use that to find out the year and with that can i then find out what gearbox an clutch i need?
any advice would be appreiciated
Thanks
Re: Gearbox woes
Post by ScottieJ » Mon Jul 02, 2012 1:18 pm
Any samurai/SJ413 gearbox will work, they are all the same. it 'should' bolt straight up to the existing gearbox mount as yours is a late 410 as far as I remember.
As for the clutch the same again SJ413/samurai they are all the same.
I presume the engine you have has the flywheel fitted?
you will also need to modify the engine mounts as the 1.3s mounts are in a different position. should only need to change one of them though I think?
Zookii
Re: Gearbox woes
Post by Zookii » Mon Jul 02, 2012 1:21 pm
ok thts good news, thanks for your help! :doublethumbs: ohh an its got the flywheel fitted.
Re: Gearbox woes
Post by ScottieJ » Mon Jul 02, 2012 1:22 pm
No worries, I also just added a few extra details to my original reply.
