fuel tank
suzukisteve
fuel tank
Post by suzukisteve » Wed Jul 04, 2012 9:57 am
morning everyone! hope everyone is cool
just a quickie, how easy is it to whip out the tank on my 410? any ideas on time?
finally gettin off my a*se and doin something :thumbup:
gonna give the tank guard a lick of paint while its out too i tink
pickle power!
Highlander
Re: fuel tank
Post by Highlander » Wed Jul 04, 2012 11:34 am
Depends if anythings seized or not :)
there's not much holding them in really, pretty self explanatory once you're underneath.
half an hour should do it no probs
Re: fuel tank
Post by ScottieJ » Wed Jul 04, 2012 12:05 pm
Highlander wrote:Depends if anythings seized or not :)
what he said! + once all 4 bolts are undone, lower it on a jack slightly so you can undo all the pipes before lowering it to the floor. most of the time the pipes from the tank are a bit fragile!
Re: fuel tank
Post by twiss » Wed Jul 04, 2012 12:40 pm
ScottieJ wrote:most of the time the pipes from the tank are a bit fragile!
read as: made of rust
Re: fuel tank
Post by ScottieJ » Wed Jul 04, 2012 12:41 pm
:lol: :lol: :lol:
suzukisteve
Re: fuel tank
Post by suzukisteve » Wed Jul 04, 2012 1:32 pm
lol made of rust indeed!! Basically some (alot) of welding is being done bu the fuel filler. i guess it would be best to drop the tank.
unless you guys know any sneaky (but safe) way of doing it without dropping the tank?
pickle power!
Re: fuel tank
Post by ScottieJ » Wed Jul 04, 2012 1:52 pm
I usually just take off the rubber filler pipe and block off the filler on the tank with some rag (obviously not stuck in so far it soaks up the petrol!) , might want to empty the tank as well, some have a drain bung on the bottom.
All this was done with the tank in place and no explosions ;)
suzukisteve
Re: fuel tank
Post by suzukisteve » Wed Jul 04, 2012 2:20 pm
brill! i was thinkin rags and rubber glove but wanted to make sure that my online wealth of knowledge
(you guys) agreed :thumbup:
she'll be welded up before ya know it!! whoop!!! :brows:
:weld:
pickle power!
suzukisteve
Re: fuel tank
Post by suzukisteve » Thu Jul 05, 2012 10:41 am
welding done!! some on drivers door, front outer wing and rear floor near fuel filler! looks the nuts! i have to confess i didnt do it tho. a mate with a workshop done it.
also removed the f*cked front bumper. made some brackets up for the side lights/ indicators and mounted em on the tubular bar that the front bumper mounted onto.
next month:
bottom of the roll hoop (if u get me)
sort arches out, maybe virtual lift??
pickle power!
Re: fuel tank
Post by ScottieJ » Thu Jul 05, 2012 10:42 am
pics man pics ;) and a build thread to go with them ;)
