Toyota 4AGE Engine 1600cc in SJ413
spacebass
Post by spacebass » Wed Jul 04, 2012 12:34 pm
Gentlemen, have the opportunity to buy one of these engines : Toyota 4AGE Engine 1600cc Inc. Gearbox ECU and harness.
Will it ft in my SJ413 (easy hard job) and is it a reasonable choice can I retain 4 wheel drive if I get it fitted.
http://en.wikipedia.org/wiki/Toyota_A_engine
and any other comments Thanking You in advance: Spacebass
http://www.rayongresortcondos.com
+66(0)815752993
"Everybodys gone to the Spacebass".
Re: Toyota 4AGE Engine 1600cc in SJ413
Post by twiss » Wed Jul 04, 2012 12:39 pm
Thats out of a mark 1 Mr2 right?
If so, its definitely possible! Rhino ray has done a few of them
I think he uses an adapter plate and the regular SJ gearbox and transmission, so yes you should be able to keep 4wd
spacebass
Post by spacebass » Wed Jul 04, 2012 1:04 pm
Yes it was used in the MR2.
Looking Good then! Thanks.
+66(0)815752993
justaddmud
Post by justaddmud » Thu Jul 05, 2012 9:18 pm
Good little engine that, I have one in my MR2
If you can find an AE86 5 speed box from the old RWD corolla, they bolt straight up, meaning all you have to do is mounts and mini prop
It is what they did on the escorts before the bell housing got cheaper
