sj413 engine advice on piston rings
jibb
Post by jibb » Fri Jul 20, 2012 11:01 pm
hi there just whipped the head of my 413 engine because its a bit smokey and wanted to know if was piston rings but i didnt do a compression test before i took the head off with oil in the cylinders,
the bores are really good condition no scores and a very minimal lip however im not sure if there should be play side to side on the piston if you push hard left to right (standing at the front of the sj it moves about 1mm.
need to know if this is normal and if euro car parts or anywhere that would have the rings in stock on a saturday will sell the 413 rings as they seem a bit hard to come by correct me if im wrong
ill get the engine number i think its an A but ill check in the morning while im rebuilding the head
thanks
Re: sj413 engine advice on piston rings
Post by ROBBIE » Sat Jul 21, 2012 10:17 am
Ive had 2 engines that were smoky. I did a comp test on both, 1 was valve stem seals, nice easy job. The other was rings, there wasnt much difference in how far the pistons moved it was more how easy it was to move them.
As for getting a set of rings rocking horse poo sprung to mind, the best i got was it could take 3 to 6 months to get them :shock:
trotter
Post by trotter » Sun Jul 22, 2012 5:54 pm
^same i did the valve stem seals on mine and all new gaskets etc on head and it still smoked so just found another engine..
if in doubt, FLAT OUT!
jibb
Post by jibb » Tue Jul 24, 2012 9:55 pm
thanks for the replies guys. just hope it was valve stem oil seals if not ill wack a 1.6 in her lol
Post by ScottieJ » Wed Jul 25, 2012 12:04 am
Robbie and Trotter did you try http://www.karengine.co.uk/Kes/BUYGUIDE/HTML/RS413.HTM
Also rings are easy to source in the US and wouldn't end up that expensive if you had to import them.
Post by ROBBIE » Wed Jul 25, 2012 10:35 am
ScottieJ wrote:Robbie and Trotter did you try http://www.karengine.co.uk/Kes/BUYGUIDE/HTML/RS413.HTM
Dont think i tried them. It was from the states that i was told 3-6 months
trotter
Post by trotter » Wed Jul 25, 2012 5:15 pm
never heard of them but its now bookmarked for when i do the rebuild on 1.6 :brows:
