weber dgv on a 1.6
muddymesser
weber dgv on a 1.6
Post by muddymesser » Sun Aug 05, 2012 11:12 am
hi i'm just after a little info on jets for a weber dgv 32/36 on a 1.6
its on my 1.3 at the moment (it seams to run a little rich at the mo) and the standard 1.6 has pipes all over the place so im not even going to try and use it
i'm just going to stick the 1.3 manifold on the 1.6 (i know not ideal but its easy and i can get the 1.6 manifold cleaned up and tweeked to go back on)
cheers
Re: weber dgv on a 1.6
Post by ScottieJ » Mon Aug 06, 2012 1:54 pm
Firstly use the 1.6 manifold or you'll be slightly restricting the engine.
From what I can find out you should be fine with the jets that are already installed, would be useful to know what it has fitted first though before you can be sure.
Also do a search on zuwharrie looking for posts by sarge, or even drop him a PM he might be able to help.
http://www.outerlimits4x4.com/viewtopic ... &start=270
http://auszookers.com/forum/viewtopic.p ... er+jetting
from what i can see a good starting point would be?
primary/secondary
idle 65/60
main 140/140
air 175/165
e tubes f50/f50
aux 3.5/4.5
