Manual locking hub 2 spring version - strip and service
Posted: Tue Sep 18, 2012 7:45 pm
by npjrogers@btinternet.com
Discovered my vit has two different manual locking hubs fitted.. One is a metal locking switch - the other is plastic which is already well documented elsewhere. Took the metal lock version apart and discovered it is a two spring version.. No the spring isnt broken.. I discovered it is the same as the toyota locking hub.. Probably made by asin. Here is the link to how to get it back together. Mine was so full of krud it was impossible to see how it went together when i stripped it.
http://www.yotatech.com/f116/aisin-lock ... up-158644/
Hope this helps other sanatana vit owners.
Nick
Belfast
