Transmission oil
Christoff
Transmission oil
Post by Christoff » Fri Oct 05, 2012 7:10 pm
Do people generally replace as it says in the Haynes book of lies? I.e EP90 or whatever it is?
Or should I go for something heavier or something that's better for it?
Re: Transmission oil
Post by ScottieJ » Fri Oct 05, 2012 7:48 pm
Sae 80w90 GL5 ;)
Christoff
Post by Christoff » Fri Oct 05, 2012 10:00 pm
Ok and would you be so kind into explaining why that is?
Iv heard slick 50 been mentioned before, apparently good for old box's.
I'm worried that I do an oil change and then make the transmission whine with the new oil which can happen I'm told...
Post by ScottieJ » Fri Oct 05, 2012 10:40 pm
Sae 80w90 gl5 is a hypoid gear oil, and pretty much the modern equivalent of ep90. It's the recommended gear oil.
I've been using it for years in my diffs, tbox and in my gearbox when it had an sj gearbox.
My vitara gearbox that I run now needs gl4 or a yellow metal safe gear oil though
Post by ScottieJ » Fri Oct 05, 2012 10:52 pm
From the samurai workshop manual
Christoff
Post by Christoff » Fri Oct 05, 2012 11:02 pm
Thanks mate quality information right there ;)
Post by Edweird » Fri Oct 05, 2012 11:13 pm
I used the same stuff as Scott
