2 Questions
First just noticed there is No Anti Roll Bar on my 1986 SJ I have bought will this have major problems I am planning to use 50% on road and the rest of the time off road.
Second My sreeing drag link has a split rubber on solid end the joint feels fine can you get new rubbers or do you have to replace whole arm
Thanks In Advance
Drag link and Anti Roll Bar
Re: Drag link and Anti Roll Bar
I've never had an anti roll bar and don't feel the need for one really, my sj is a daily drive.
Only laters sjs had them fitted. I don't hang about in my sj either.
You should be able to replace the rubber? Not sure where you would by the rubber separate either??
Had a "Google" and this company says number 1 fits the SJ !!
http://www.balljointboots.co.uk/
- tie rod etc.gif (34.92 KiB) Viewed 5567 times
If its 1986 chances are that from standard it never had an anti roll bar fitted, the way to tell is by looking at your spring plates(what the u bolts attach to) on the wheel side, there will be a threaded sleeve (if it ever had an anti roll bar fitted)
