sj throttle cable to short to webber carb
ginns
Post by ginns » Sun Nov 04, 2012 4:50 pm
hi guys im new to the site im after a bit of help ive just brought a sj but the throttle cable was naffed so i had go a second hand one and it seems to short for my webber car as its making the throttle stick on it was removed from another anus thats also had a webber fitted could enyone help ??? cheers shane :D
Re: sj throttle cable to short to webber carb
Post by Darrell » Sun Nov 04, 2012 5:04 pm
I believe bicycle cables work well for this. Maybe worth taking it to the bike shop to make sure it has the correct nipple for the pedal end. If I remember correctly the carb end is just a clamp for the cable outer and a screw on nipple.
Post by ROBBIE » Sun Nov 04, 2012 5:14 pm
As Darrell said bike cable works, a rear brake cable is long enough but the nipple will need filing to fit the pedal
ginns
Post by ginns » Mon Nov 05, 2012 8:13 pm
ok cheers
