1.6 injection help
dunnin21
1.6 injection help
Post by dunnin21 » Mon Nov 05, 2012 1:01 pm
I'm in the middle of a 1600 conversion, iv dropped the engine in and the top of the inlet/throttle at top of engine is touching the bonet. Will I have to adapt something or will it be ok once it's all bolted up. Also has any one that's done this convesion with the injection point me in the right direction for the wirring setup as I'm not to sure on it
Re: 1.6 injection help
Post by ScottieJ » Mon Nov 05, 2012 3:44 pm
It should clear? has your sj got the later 413/samurai bonnet with the taller middle section?
dunnin21
Post by dunnin21 » Tue Nov 06, 2012 8:15 am
Yes it has, just looks close it's a sammy 413
dunnin21
Post by dunnin21 » Wed Nov 07, 2012 8:13 am
Anyone done the 1600 injection conversion
Post by ScottieJ » Wed Nov 07, 2012 11:25 am
Is it an 8v spi or 16V mpfi?
dunnin21
Post by dunnin21 » Thu Nov 08, 2012 7:34 pm
its a 8v spi. i was wondering what people did with the manifold and the o2 sensor. did you use the sammy manifold and exhaust and drill a hole foe o2 sensor. all help appreciated, Thanks
Post by ScottieJ » Fri Nov 09, 2012 1:19 pm
although my 1.6 conversion is carb i managed to use the vit manifold and downpipe. have you got those? I would imagine it should fit ok.
If not I have a 1300 spi manifold in my workshop ;)
sam16v
Post by sam16v » Tue Nov 13, 2012 8:56 pm
Ive done the 1.6 injection swap, i ended up fabricating my own engine mount brackets though to get the engine sitting right. How did you get on with the injection wiring?
