Propshaft info
Propshaft info
Post by ScottieJ » Mon Nov 05, 2012 1:53 pm
Darrell wrote:Questions have popped up quite a few times regarding propshafts and I don't know of a useful list of measurements. So I've done a diagram (there's a surprise) and hopefully you guys with spares can get a few measurements for future reference.
The pcd can be worked out as length C divided by 0.707
My D reg SJ413 ,The only info I have is
A= 8mm
C= 56mm
PCD= 79.2mm
Universal joint size =
Well it's a start :oops:
Re: Propshaft info
Post by ScottieJ » Mon Nov 05, 2012 1:57 pm
Dimensions I have found so far.
Christoff
Re: Propshaft info
Post by Christoff » Mon Nov 05, 2012 4:46 pm
Are all the UJ's interchangeable or is it best the swap the whole shaft? I have noise coming from the front & middle one.
Re: Propshaft info
Post by Darrell » Mon Nov 05, 2012 6:30 pm
Well done Scottie :doublethumbs:
kiwizook
Re: Propshaft info
Post by kiwizook » Fri Feb 01, 2013 9:07 pm
Can the shaft from the gearbox to the t box be removed just like that, or do I have to line it up as it is in the gearbox when I put it back? I was thinking the shaft will be balanced when of the gearbox, but am not sure
Re: Propshaft info
Post by ScottieJ » Fri Feb 01, 2013 9:11 pm
Yeah just pull it out and put it back wherever it slots back in :thumbup:
Re: Propshaft info
Post by Darrell » Sun Apr 14, 2013 12:07 pm
:suzuki:
propshaft info.jpg (115.41 KiB) Viewed 30944 times
HuwJones
Re: Propshaft info
Post by HuwJones » Mon Apr 22, 2013 10:01 pm
Suprisingly my Samurai passed it's MOT the other day with only one advisory, the yoke on the rear propshaft is worn. I took the 'pivot' off and measured it with a micrometer and it was reasonably round (a lot closer to round than the yoke!) So i've decided to replace it.
I was wondering if it was possible to buy new propshafts? I'm not a fan of replacing worn parts with slightly less worn parts, it defeats the point.
Thanks
Huw
There's three ways of doing things,
1) The Right Way,
2) The Wrong Way
3) My Way.
2 & 3 are usually the same.
Re: Propshaft info
Post by ScottieJ » Mon Apr 22, 2013 10:26 pm
Can you explain exactly what parts you are measuring im not sure which exact bit you mean by the 'pivot'? Is it the outside diameter of the bearing cap that you are measuring and the internal diameter of the yoke? The UJ bearing caps should not move within the yokes and be a tight fit so there shouldn't really be anyway that the yokes can wear? It's usually just the universal joint that develops play and need replacing.
You probably can get a new prop from Suzuki but be ready for a shock when they tell you the price.
HuwJones
Re: Propshaft info
Post by HuwJones » Mon Apr 22, 2013 10:32 pm
This is the bit that i mean. It isn't a tight fit at all.
1) The Right Way,
2) The Wrong Way
3) My Way.
