webber carb probz with snorkle
Hi guys just fitted a snorkle
used 2" pipe toped with a mushroom head filter
power has droped badly cant get over 30 on the road wer id normally get 50 it keeps boggin out
shall i ditch the webber carb and get a su?
just had the worst day out in it ever lol
Re: webber carb probz with snorkle
You might be getting carb freeze. I had the same problem with my old weber and snorkal setup. I had to cut a hole in my snorkal pipe so i could connect the hot air feed up.
Is that the pipe witch gies to manafold and the the head
i have an ooen end on it naw as ut used to be on the filter?
There is a flexy pipe that attatches to the exhaust manifold and the original air box. It may have been removed when the weber was fitted.
If it was running fine with the weber before, then you fitted the snorkle and now its it shit I think it may be a problem with the snorkle, id check for kinks or anything that would reduce the diameter and cause reduced flow inside it
The feed was on i removed it wen i put snorkle on
startin to think thats wer the prob is naw
thers no kinks and iv made it as short as possible
i took it all off and ran it with no filter made no diffrence
still bogged
still bogged
Can you post a pic of your snorkel set up? What I do is run the snorkel off the original air box and seal it all up with silicone sealant. Then I would dissconnect the hot air feed and fit a rubber glove over the hot air feed intake when out offroading to seal it up for wading.
Its heavly taped up lol
any advise on doing the mixture on carb guys?
- 2012-11-18 15.04.37.jpg (1.42 MiB) Viewed 7402 times
- 2012-11-18 12.08.10.jpg (1.51 MiB) Viewed 7402 times
Ermmm an air filter would be a good idea!!!!! if it was running fine before the snorkel I doubt it's anything to do with the mixture. There's not actually a filter in those snorkel tops is there?
Running an air filter is even more important when running a snorkel. I would refit the air box and run the snorkel from there.
K thanks mate
no ther no filter in ther :(
il sort it after wrk tomoz
just conected up the filter with a few mods of the 2" pipe
but it dont bend nice..would 44mm pipe work to join to the existing 2"snorkle pipe as it bends much easyer?
thinkin it will restrict too much air?
