Play In Rear Diff Pinion
Famerbennie
Post by Famerbennie » Sun Dec 02, 2012 5:12 pm
Hi Everyone, Got Some Play In Pinion Of Rear Diff And Was Just Wondering Has Anyone Else Had Problems In This Area, And Whether It Deteriorates Fast Or Just Leave It Until A Later Time?
dazerede
Re: Play In Rear Diff Pinion
Post by dazerede » Sun Dec 02, 2012 6:15 pm
Ye I had that problem its called a pinion bearing well I just replaced it when I noticed it so I ordered it from Suzuki it was only a couple of quid but it was a Fuc**r to get out
4” calmini lift kit :)
Post by ScottieJ » Sun Dec 02, 2012 6:27 pm
To do the job properly you need the 2 pinion bearings a new crush collar and oil seal. The diff also needs to be stripped and the backlash Set up properly. Where in the country are you I can rebuild diffs.
Famerbennie
Post by Famerbennie » Sun Dec 02, 2012 6:34 pm
I'm Just Outside Chelmsford In Essex If Thats Any Help
pistolpete
Post by pistolpete » Mon May 13, 2013 11:44 pm
sorry to revive an old thread but could anyone tell me the prices and part numbers for the bits required when changing the pinion bearing and seal. have had a good search but cant find too much about it. thanks
Post by dan_2k_uk » Tue May 14, 2013 6:45 am
