can any 1 help?
damo
can any 1 help?
Post by damo » Sat Dec 08, 2012 12:51 am
hey there guys ive recently bought a sj413 1.3 its a 1989 i use it on and off road but im new to off roading. any way the question is wheni get up every morning and leave the house i have to sit there for a good 5 minutes reving it or it just cuts out on me and it wont tik over but once it is warm it runs bang on its just when the engine is cold. could any body give me any advice please or know a cure it would be much appreciated
cheers
Re: can any 1 help?
Post by ROBBIE » Sat Dec 08, 2012 8:36 am
Has it still got its original carb? If yes thats more than likely your problem
Re: can any 1 help?
Post by Jordi » Sat Dec 08, 2012 9:40 am
As Robbie said. The original carb has an automatic choke on it. It's usually the first thing to break. It stops opening to let more air and fuel in when the engine is cold.
You can get carb rebuild kits but i would waste your time. Plenty other carbs will fit straight on if hou can het hold of one.
damo
Re: can any 1 help?
Post by damo » Sun Dec 09, 2012 2:44 pm
cheers lads
Jay18
Re: can any 1 help?
Post by Jay18 » Sun Dec 09, 2012 3:53 pm
i have the similar thing with my 410, but that has a manual choke, they just need the choke opening right up and once the engine is warm she runs like a dream, but if yours has auto choke then like whats already been said give the carb a good clean and if the problem is still there then either fit a SU carb or get a rebuild kit for your current carb...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
damo
Re: can any 1 help?
Post by damo » Mon Dec 10, 2012 12:29 am
it has the manual choke on it i will have to have a look at that then. does any 1 know how much an su carb is? and would that improve the speed? i know there not built to go fast but when im going down the motorway im flat out at 60 and if i hit a hill goes slower even wagons go around me lol
charger
Re: can any 1 help?
Post by charger » Wed Dec 12, 2012 12:47 pm
I had my stock carb serviced & it's running ok right now, how long that will last I don't know.
1991 Samurai
Rough Country Lift/Shocks
Cherry Bomb Exhaust
Bronco Diamond Back 215/15
Llama Brake Hose
