As well the other problems I have I am having a moment with the cooling fan!
When I bought the suzuki there was a electric fan which I may as well keep.
It is mounted on outside facing the radiator (Not where original fan is mounted) The fan I can wire this up 2 ways either Blowing air in or Blowing out warm air.
Am i just being a bit thick what does the normal fan do ??????
Cooling Fan
Re: Cooling Fan
It should blow cold air in
Re: Cooling Fan
The original fan sucked air through the rad
