Brake pads
Posted: Mon Jan 14, 2013 10:14 am
by miketree
When I bought my '99 vit, there was a box of brake pads in the boot.
The box is labelled SJ410.
Are these compatible, or did somebody buy the wrong ones?
Re: Brake pads
Posted: Mon Jan 14, 2013 10:19 am
Can you post up a picture/part number
Re: Brake pads
Posted: Mon Jan 14, 2013 12:54 pm
by vitara_mad
its possable they are the right pads best thing to do is check yours only takes 2 mins to unbolt a caliper
Re: Brake pads
Posted: Mon Jan 14, 2013 3:11 pm
by suzukisteve
not that it'll help much with this problem but I've got an app on my phone called teccat. I think for the iphone it'll be tecdoc. hut they cross over part numbers for most makes. its really handy for at work.
got it from Google play store
Re: Brake pads
Posted: Sat Jan 19, 2013 2:00 pm
by miketree
Here's the label.
Re: Brake pads
Posted: Sat Jan 19, 2013 3:38 pm
by Anton
The little pic on the box looks like Lucas/Girling 48mm piston caliper pads to me, as fitted to - well, all small 4x4 zuks at one time or another, I think - if not as factory, definitely as a bodge by someone.
Take one of the front wheels off and see if the brake pads in your calipers have the little spring thingy at the top - it should kinda poke out of the caliper (sort of, from memory). If not, take a picture of the caliper and maybe we can tell you which pads you need.
