Question *REV counter*
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 5:01 pm
just wired up the 1600 vitara SPI limp into the sj. Is there a way for the standard sj rev counter to work with the vitara engine
Re: Question *REV counter*
Post by Edweird » Fri Jan 18, 2013 5:20 pm
I would guess yes, but I'm not sure.
Post by ScottieJ » Fri Jan 18, 2013 5:49 pm
Brown (possibly with white tracer) to coil negative as far as I'm aware. I.e. the same way it was wired up before.
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 7:47 pm
I didnt do the wiring so wasnt sure, any pics or how to. Would I have to trace the wire back to the ac ult gauge on dash
Post by ScottieJ » Fri Jan 18, 2013 7:55 pm
I would imagine there will be a brown wire hanging out of the loom near the coil still ;)
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 7:59 pm
im with you now Scottie, thanks ill start with that
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 8:18 pm
I think I rember seeing the wire you talking about from the sj wiring. What do I attach this wire to for the revs to work
Post by ScottieJ » Fri Jan 18, 2013 8:35 pm
Coil negative :thumbup: pretty sure there's a noise suppressor that should be in there as well somewhere though
Post by ScottieJ » Fri Jan 18, 2013 8:38 pm
One of Darrell diagrams for you
dunnin21
Post by dunnin21 » Fri Jan 18, 2013 8:43 pm
Thanks, is this the same on the vit engine with it being a injection
