Santana SJ410 Water temperature sensor
DaveB
Post by DaveB » Sun Jan 20, 2013 10:47 am
Hi,
I have inherited my late son's 1988 Santana. I can't sell it and try to keep it roadworthy and use it as much as I can. Since I have had the car the temperature gauge has not worked. After a real struggle to remove the sensor I fitted a new one which had a bullet connector rather than a spade connector and now the gauge goes quite quickly to overheat, but the engine temperature is still normal. I purchased a new sensor from another supplier (again bullet connector) but still have the same result. I believe the sensor is wrong but I have tried various suppliers and websites but can't seem to find the one for my 970cc Santana.
Does anyone know where I can get a suitable sensor or is it the gauge that is faulty?
Many thanks, DaveB
ferris
Re: Santana SJ410 Water temperature sensor
Post by ferris » Sun Jan 20, 2013 11:32 am
:welcome: to the club :thumbup: .
I would probably try the main dealer, there prices aren't usually that bad on smaller parts . It might cost a little more but at least you know your getting the right part. I went to my local motor factors to get a oil filter for my SJ. They tried 2 different parts supplyers and they both came back with different filters, both of them wrong! :er:
DaveB
Post by DaveB » Sun Jan 20, 2013 11:50 am
ferris, many thanks for the reply. I will try the main dealer, the reason I didn't is because I believed the age of the car they may not have stocked spares, but I will give them a try. I live in Bristol and the one I knew of closed a couple of years ago. I beleive there is another though.
Again, thanks for reply, much appreciated
ferris
Post by ferris » Sun Jan 20, 2013 12:00 pm
surprisingly they can still get most parts, although they can be quite expensive on some things. I use Roadworthy Suzuki on Fishponds road. There pretty good and can usually get parts in the next day.
DaveB
Post by DaveB » Sun Jan 20, 2013 12:11 pm
Thanks, I'll certainly give them a try, the one I knew of was at Avonmeads, but they changed franchise some time ago.
The 4x4 is certainly worth having in this weather, thanks again
Pugsley
Post by Pugsley » Sun Jan 20, 2013 7:51 pm
Dave
If and when you visit your local Suzuki dealer for the sensor, make sure you have the full chassis number at hand. Without it they cannot order a part correct for the vehicle - will save you a trip home and back again.
Post by Darrell » Sun Jan 20, 2013 8:02 pm
I must admit I've had another good look around and can only find one type, the one with a bullet connection :er: :cry:
http://forum.suzukiclubuk.co.uk/vi ... %20sender/
Hope Suzuki can sort it for you.
Edited due to wrong link. (How did I manage that :screwy: )
Post by ScottieJ » Sun Jan 20, 2013 8:14 pm
I presume the sender has an m16x1.5 thread? all the ones in that size I have seen have bad a bullet connector.
Any chance of a few pics.
1 of the original sender
1 of the engine
And one of the clocks.
Might sound like a strange request I just want to make sure everything is original :thumbup:
dazerede
Post by dazerede » Sun Jan 20, 2013 8:22 pm
Oops replied in the wrong section
Here is the box that it was in and the pic of the sensor on got it about a year age it was about 4.50
4” calmini lift kit :)
Post by Darrell » Sun Jan 20, 2013 8:23 pm
I can tell what your thinking Scott (1300) may be ;)
