tyres....how big can I go? what do you recommend?
theboy
Post by theboy » Thu Jan 24, 2013 7:47 pm
Hi Guys,
with a samurai just with add a leaf what size tyres do you recommend i can go to comfortably?
Im looking at Insa Turbo Sahara. My Suzuki rims seem to be slightly deeper dish on the front and a even more on the back as apposed to what I normally see on theses jeeps as standard (not sure if they were an upgrade?)
cheers
tom :D
Re: tyres....how big can I go? what do you recommend?
Post by ScottieJ » Thu Jan 24, 2013 7:58 pm
I'd say something equal to 30" maximum and you might still need to fold over the seams over at the back of the front arches so they dot catch.
Post by Jordi » Thu Jan 24, 2013 8:03 pm
As scottie says. Upto 30" is ok. Any bigger than that and the problem is bulkhead clearance. I have 31s on. Did a virtual lift to start and had to take approx 3" out of the bulk head for adequete clearance on articulation.
Now running +1.5" springs and they still use most of the space i created when i cut the bulkhead.
theboy
Post by theboy » Fri Jan 25, 2013 4:33 pm
cheers for the replies guys,
Do you literally hammer the seam flat or is it best to put little cuts in with an angle grinder then fold over?
These are the tyres im thinking of from camskill - insa turbo Sahara
which one of these would be best with my limited modifications, you say i can go up to 30" but just wondered which of these sizes suits best -
Im guessing a 215/80/15 might be ok? the anus currently has 205/70/15 at the moment
size options in sahara -
R15" - 195/80/15, 195/80R15
R15" - 195/15, 195R15
R15" - 215/75/15, 215/75R15
R15" - 215/80/15, 215/80R15
R15" - 215/15, 215R15
R15" - 31/1050/15, 31/10.50R15
cheers, Tom
Post by ScottieJ » Fri Jan 25, 2013 4:50 pm
theboy wrote:cheers for the replies guys,
I just hammered mine over
R15" - 195/80/15, 195/80R15 27x7.68
R15" - 215/75/15, 215/75R15 28x8.46
R15" - 215/80/15, 215/80R15 29x8.46
cheers, Tom
I'd go for either of these
31x10.50 would probably be too big.
Post by Jordi » Fri Jan 25, 2013 5:16 pm
215 75s are r
Post by ScottieJ » Fri Jan 25, 2013 5:26 pm
Jordi wrote:215 75s are r
:er:
Post by Jordi » Fri Jan 25, 2013 5:34 pm
Wrf. Phone malfunction!
Post by ScottieJ » Fri Jan 25, 2013 5:41 pm
Wrf :er: what's that mean I'm still confused :lol:
theboy
Post by theboy » Fri Jan 25, 2013 5:42 pm
Jordi wrote:Wrf. Phone malfunction!
im still lost? can you explain!
