Just wondering if anyone has or has not fitted one when using SJ calipers and discs on the rear.
Gathered 99% of the stuff to do the conversion. Just need to clarify this issue for the MOT man.
Brake bias valve
Brake bias valve
Re: Brake bias valve
My 413 has this thing on it, i think is some sort of proportioning valve. Does the Samurai not have any thing like that on it?
- justaddmud
- Can I have a tow
I bought and will be installing a manual adjustable valve as i have been in a suzuki that has a rear disc conversion, and even with the proper bias valve fitted, I still didnt like the fact that the rear had a tendency to lock up before the fronts, plus with the adjustable valve if i am carrying a load, i can feed more power to the rears, and if i am towing i can adjust the brakes accordingly, not that expensive for an item and will give would perfect control
I'm mine has got some kind of valve but i'll have to check when i get in.
Which valve have you got? And how much if you don't mind.
Thanks
Thanks
