vitara rear spring length
i have a problem on my vit,one of the rear springs appears to have sagged down about 50mm.
i need to know the length of a vitara rear spring compressed on flat ground as i need to check if i have stock springs or if one has been swapped to a gv spring.
its a swb soft top 1.6 16v if that makes any difference.
If at First You Don’t Succeed Skydiving Is Not for You
Re: vitara rear spring length
does anyone have any ideas about this.
i want to replace the spring thats sagging but i need to know what spring to replace it with
Sorry I can't help with the length but I would think its probably better to replace the pair so that you know you have a matching set.
i was going to but if they are gv springs i need to know so i can replace them with the same springs.
but if they are stock and i swap to gv springs then truck wont sit right.
im just trying to find out which springs i need
if you remove a spring & measure it i will measure a standard vit spring to compare size
i dont have a standard vit with standard springs to measure on the vehicle with spring compressed
i will try when i get chance but i am using it reguarly since it is my only transport at the moment
i would appreciate the measurements though,thanks for your help
can some one confirm that these grand vitara springs are the right ones to fit my truck?
http://www.ebay.co.uk/itm/Suzuki-GRAND- ... 99c&_uhb=1
they will fit
thanks,
do you think they will give me good articulation as it doesnt say if they are for a swb or lwb.
