If a cambelt snaps on sj413?
theboy
Post by theboy » Sun Feb 10, 2013 3:57 pm
Hi guys,
Just wondered if a cambelt snaps on a 413 engine will be likely or less likely to cause permanent damage......? Bent valves etc?
Re: If a cambelt snaps on sj413?
Post by turbo-tom » Sun Feb 10, 2013 4:15 pm
if it snaps it snaps it wont damage the motor as its a non-interference engine so the pistons wont smash the valves its just a case of lining the camshaft up and the crankshaft up and pull back tensioner and fit the new belt ;)
theboy
Post by theboy » Sun Feb 10, 2013 4:37 pm
turbo-tom wrote:if it snaps it snaps it wont damage the motor as its a non-interference engine so the pistons wont smash the valves its just a case of lining the camshaft up and the crankshaft up and pull back tensioner and fit the new belt ;)
Ah that's good to hear, is changing the belt a simple job on one of these?
Post by turbo-tom » Sun Feb 10, 2013 4:53 pm
yeah its really easy aslong as all the bolts come out and you have a good selection of tools you will be fine.
i cant really find a how to guide atm
ive stolen this picture from autodata just to show how simple it is
id say you could do one in aout 30-45mins if your quick on the spanners ;)
Post by Edweird » Sun Feb 10, 2013 5:07 pm
turbo-tom wrote:id say you could do one in aout 30-45mins if your quick on the spanners ;)
Oh yeah, easily. I managed it in about an hour just going in blind.
Post by Darrell » Sun Feb 10, 2013 5:30 pm
It says in the workshop manual to slacken all the valves off to allow the camshaft to rotate freely and therefore allow the cambelt tensioner to work correctly. Sounds a lot of fluffing about, do people bother with that???
Post by ROBBIE » Sun Feb 10, 2013 5:34 pm
Darrell wrote:It says in the workshop manual to slacken all the valves off to allow the camshaft to rotate freely and therefore allow the cambelt tensioner to work correctly. Sounds a lot of fluffing about, do people bother with that???
Never have
Post by turbo-tom » Sun Feb 10, 2013 5:48 pm
Never have
never have new will to line it all up id say take the plugs out so you havent got to fight over compression!
Post by Darrell » Sun Feb 10, 2013 5:51 pm
Cheers guys, didn't think people bothered :D
Post by Jordi » Sun Feb 10, 2013 7:24 pm
Cambelt. No more than 45minutes ish. Old one off, don't fck with anything. New one on and away we go.
I might even put new tensioner on when i do the 1600. With my new RW manifold, and rocklobster. And shiny alloys. Also those nice rust free doors and bonnet. Did i also mention i have chrome wing mirrors in the post.
