Page 1 of 2
king pins
Posted: Mon Feb 11, 2013 9:14 am
by suzukisteve
alright guys, a quick question. about the king pins on my sj.
ive got a fair amount of play in the nsf king pin. are they shimmed? if so i should be able to remove a shim or two to take up the slack?
failing that does anyone know a good supplier?
cheers
Re: king pins
Posted: Mon Feb 11, 2013 9:54 am
by ROBBIE
Should be shimmed unless some one done them already. Do you get your parts from your local motor factor? he should be able to get them
Re: king pins
Posted: Mon Feb 11, 2013 10:00 am
by suzukisteve
I work at my local motor factor lol. phoning around our suppliers as we speak
hopefully the shims are in there. save a bit of dosh hopefully
Re: king pins
Posted: Mon Feb 11, 2013 10:09 am
by dan_2k_uk
I wouldn't even bother removing shims to keep them going having done it to mine and having them fail a few K later once I had lost all the shims I removed!
Once the races have started wearing its time to change them anyway.
Some decent timkin bearings were only £15 so l'm sure you could find some cheaper ones.
Re: king pins
Posted: Mon Feb 11, 2013 10:19 am
by suzukisteve
awesome gonna call brt bearings shortly as well. is there a part number for the timkin bearings?
Re: king pins
Posted: Mon Feb 11, 2013 10:23 am
by dan_2k_uk
15x42x14.25 metric taper roller bearing 30302
Just ask what brands they supply and choose a price that suits you.
As per usual more you pay better you get.
Sure the bearing company will be able to help. Suzuki wanted £120 for a full set!
I figured bigger tyres means more stress so went for the best they had.
Re: king pins
Posted: Mon Feb 11, 2013 10:27 am
by suzukisteve
yeah thats fair, cheers for your help dan. very much appreciated!
Re: king pins
Posted: Mon Feb 11, 2013 10:54 am
I'm cheap so I always pull the shims to get a bit more life out of them.
Suzuki use KOYO bearings as standard
Re: king pins
Posted: Mon Feb 11, 2013 11:15 am
by suzukisteve
yeah ill see how my bank account feels about the price otherwise its shim removal time! lol
Re: king pins
Posted: Mon Feb 11, 2013 12:16 pm
by ROBBIE
Steve who do you work for? I only know one company over your way
