Page 1 of 3
1.6 8v engine clearance issue?
Posted: Wed Feb 27, 2013 8:43 am
by Richie
Finally got the G16A engine and gearbox bolted in but the dizzy cap just hits on the bulk head.
Before i get out the BFH :lol: i just wanted to make sure ive not done anything stupid. Anyone else had a issue with theirs being alittle close at the back?
Also the prop that runs from the gear box to the transfur box i think was a 413 and was about 1/3 inch to long so ive had to use the slightly shorter 410 one which went in lovely, just thought i would point these things out as not seen anyone mention they had a issue with them in any other conversion builds.
Re: 1.6 8v engine clearance issue?
Posted: Wed Feb 27, 2013 9:04 am
by dan_2k_uk
If it is an early 410 I seem to recall the rear gearbox crossmember is slightly different. Maybe causing your engine to sit further back and foul bulkhead and require shorter prop.
Posted: Wed Feb 27, 2013 6:51 pm
by Richie
its a E reg if that helps?
Posted: Wed Feb 27, 2013 11:02 pm
That should have the later gearbox mount so that's a bit odd, did you mount it up a standard gearbox mount and then do the engine mounts? Maybe a few pics of everything would help us see what's going on, the dizzy shouldn't foul the bulkhead :er: should be at least 1" clearance.
Posted: Thu Feb 28, 2013 8:39 am
by Richie
The engine and box were to hard to lift together so i seperated them.
First lifted the engine and sit in it place and bolted down the n/s (standard) engine mount.
Then i rested the engine down on the o/s half complete engine mount, the gear box at this point just about lined up with the gear box mount. So i bolted this down then put the spacer in for the o/s mount and bolted that down.
The only thing that was abit unexpected was the o/s mount would of sat way to high and was nowhere near going to line up so i turned it upside down? It was then alot closer.
If anyone has a couple of pics of their mount? maybe im doing it completly wrong...
Still doesnt explain why i had to use the slightly shorter prop, unless everyone has to?
Posted: Thu Feb 28, 2013 11:56 pm
by dan_2k_uk
Think both mounts nees modding for a 410. Think its just 1300 mounts that line up.
Might be wrong.
Posted: Fri Mar 01, 2013 11:13 pm
by Richie
Ok this is my n/s mount (this is how it was bolted to the engine in my other truck) plz correct me if its wrong
Posted: Fri Mar 01, 2013 11:15 pm
by Richie
This is the o/s mount layed in place with i think 1 bolt holding it inplace (this one im not sure about)
Posted: Fri Mar 01, 2013 11:16 pm
by Richie
o/s mount again (i think the bracket i put on upside down)
Posted: Fri Mar 01, 2013 11:18 pm
by Richie
This is the gear box mount
